The process that gain Centrifugal Spray Dryer
Home / Forums / Product Reviews / Equiptment / Tools / The process that gain Centrifugal Spray Dryer
  • July 14, 2014 at 11:41 am #46972
    As a result of the improve in efficiency of conventional cooling dehumidifier dehumidifier, straight under the influence of cooling efficiency, even though enhancing the refrigeration efficiency of current limit values. In response to this predicament, depending on the classic principle of dehumidifiers, were constructed in between the evaporator and condenser heat exchanger. [b][url=http://www.ymdrying.com/centrifugal-spray-dryer-17.html]Centrifugal Spray Dryer[/url][/b] wind machine will wet air from left above entrance inhalation, wet air very first via air heat exchanger and from evaporator of cryogenic dry air for hot Exchange, its temperature was decreased, corresponding of cryogenic dry air of temperature also when was elevated, temperature was lowered Hou of wet air continues to forward flow to evaporator for 2 instances cooling makes its reached wet air of dew point temperature following will its water precipitation.
    As a result of wet during this course of action is not sent directly towards the evaporator cooling and dehumidifying the air, as opposed to via the air with cold dry air from the evaporator of the heat exchanger for heat exchange, as a result, reaches the evaporator wet moist air might be sent directly to the evaporator the air temperature is low, therefore lowering the [b][url=http://www.ymdrying.com/continuous-fluid-bed-dryer-26.html]Continuous Fluid Bed Dryer[/url][/b] evaporator burden, improving the efficiency of dehumidification.
    Energy-saving cooling dehumidification machine in cooling dehumidification machine depending on enhanced among evaporator and condenser happen to be air heat exchanger. First right after moist air in to the dehumidifier and air from the evaporator flows by means of heat exchanged cooled, then flow to evaporators further cooling and dehumidifying, which decrease the heat load of your evaporator, so in case of entering precisely the same energy to take away a lot more moisture, improves [b][url=http://www.ymdrying.com/double-cone-vacuum-dryer-21.html]Double Cone Vacuum Dryer[/url][/b] technique of dehumidification efficiency, accomplish the aim of energy saving. Theoretical evaluation and experiments showed that this method can save particular application 20%-40%,therefore has a value.
