Tinting a Candy
Home / Forums / Main Forum / Paint and Refinish / Tinting a Candy
- This topic has 19 replies, 7 voices, and was last updated 14 years, 10 months ago by Teyhren Ramdon.
- AnonymousJanuary 22, 2010 at 7:20 pm #18852
I’ve got a motorcycle part here off a 96 Harley 1200 xl (paint color name is sunglo red) and the closest color I see is Crimson red sunglow but appears to be for an 08-09 Harley. I am missing a toner to mix it but I will have it on monday to see how close it is. In the case of having to tint it, how do you guys handle this kind of thing? should I try and tint the groundcoat or the candy first?
January 22, 2010 at 8:51 pm #18853I’ve found that the base match is more critical in obtaining an acceptable match. Candy coats are a little more forgiving so long as its the correct color. The hard part comes when trying to figure how many coats of candy it takes to shift the color to match.
AnonymousJanuary 23, 2010 at 1:08 am #18858[b]Joe@FCAB wrote:[/b]
[quote]You know how to do a let down panel dont you Jimmo?[/quote]I think so, just a fancy word for spray out card isn’t it? :blink:
January 23, 2010 at 1:14 am #18859[b]jimmo wrote:[/b]
[quote][b]Joe@FCAB wrote:[/b]
[quote]You know how to do a let down panel dont you Jimmo?[/quote]I think so, just a fancy word for spray out card isn’t it? :blink:[/quote]
Same premise, but a with a letdown card you spray your base color out (I usually let it dry, then mask off some bare base) then one coat of candy over the whole card, let it dry, mask it off (usually about an inch), spray a second coat over the whole card, let it dry, and mask that one off, spray a third…… I usually do 6-7 “steps”,unmask all the candy then clear.
Gives you a good idea as to how many candy coats will get you there.
January 23, 2010 at 1:17 am #18860Another thing you”l see is when you start to get more and more coats of candy on, you’ll see less drastic change between each additional coat.
January 23, 2010 at 4:38 am #18866well, to make life alittle easier…maybe, if there is another shop near you that you are friendly with that is ppg just have them mix it for you. ppg makes harley’s paint so they have the formulas for it. otherwise harley doesn’t give out their paint codes or formulas at all. also, if you decide to use rm, dont bet for a minute that their colormatches for any of the motorcycles are going to be anywhere in the realm of a match or even close. some do and some are so bad its not even in the same color family. the base color is going to be the biggest factor in the match. candy colors are generally the same from one paint company to the next because all the dyes come from one manufacturer. harley on the other hand ALWAYS likes to modify colors a bit just so a shop cant or has a real difficult time doing a colormatch…not every color but alot of them. for instance if they use a cnady red they will put just a drop of another color to slightly change it. you’ll shoot the candy red thinking thats all it is but never ends up being a perfect match. i have seen harley go so far as to have pigment maufacturers make a custom pigment or effect toner specifically for them which is not available to any paint company. i see this happening more and more on newer models. btw in smartrack there are some harley codes under motorcycles and alot more under fleet. good luck there jimmo!! :exci
AnonymousJanuary 27, 2010 at 6:48 am #18954This is what I have now, slightly off….boss man thinks it’s close enough but my standards are a bit higher, would like to get a little closer.
[img]http://img121.imageshack.us/img121/7923/pict0014fx.jpg[/img]
[img]http://img34.imageshack.us/img34/4784/pict0017jv.jpg[/img]
[img]http://img148.imageshack.us/img148/7576/pict0016cs.jpg[/img]
[img]http://img141.imageshack.us/img141/5057/pict0001pf.jpg[/img]
Groundcoat color
[img]http://img62.imageshack.us/img62/5417/pict0004ok.jpg[/img]
What do you guys think I should do with this? It depends on the lighting somewhat, you can see under the sungun it looks pretty good (last one).
January 27, 2010 at 10:02 am #18959i think it needs some more black ta dirty it up some more an mabey a couple more coats of mid coat hard ta say without seeing the formula whats in it??? :unsure:
January 27, 2010 at 10:05 am #18960looks like it need more yellow or gold shade mica in it but cant tell what ya got without a formula your close but no cigar
January 27, 2010 at 10:07 am #18961looking at your pics it looks like the sidetone is good but your face is off :unsure:
