Uncleared water base
Home / Forums / Main Forum / Paint and Refinish / Uncleared water base
- This topic has 22 replies, 12 voices, and was last updated 12 years ago by Scott.
We are painting a 09 Kia Borrego rear bumper cover Lower. Its a silver paint code WF. The original paint is an uncleared base. We spray Cromax Pro. Anyone had experience with this procedure before with water based? Wondering if we just activate the base and spray.
March 22, 2013 at 12:14 am #42309I’m not familiar with car but are you sure it’s not done with matt/flat clear? I can’t see them just leaving a bumper in base :unsure:
AnonymousMarch 22, 2013 at 12:21 am #42312If you apply the basecoat without a matte clear or something it won’t have very good UV protection and will likely chalk up/fade fairly quick. I don’t know what is on it from factory but it’s always been against manufacturers recommendations to leave basecoat uncleared where exposed to sunlight.
March 22, 2013 at 5:04 pm #42338You have to clear all basecoat as it will not stand up to UV exposure very long at all. Ding is right it’s just a SS matte color, nothing special.
Just use a matte clear over the base and call it done.
March 22, 2013 at 11:02 pm #42350Not fully on topic, but just as I left my last job Debeer were introducing an additive for their water base so it could be used un-cleared on under hood areas and the like.
March 23, 2013 at 2:50 am #42358Sherwin AWX has an activator also, but not really recommended for exterior use mainly under bonnet and interior areas.
I know if you left uncleared waterborne, the rain and car washing will eventually dissolve it away. Have seen several cases of waterborne washing away from stonechip areas, a few from sikkens but for some reason a fair few from de beer.
Products using pure de ionised water instead of a waterborne reducer also seem to be a little more prone to weathering if exposed.I know we’re heading off topic but that is interesting, Rep. I haven’t used waterborne but always thought that it was like water based house paint in that once it had dried it was no longer water soluble. What you’re saying is that is not the case but that it can, eventually, be washed away.
