Upol raptor bedliner
Home / Forums / Main Forum / Introductions / Upol raptor bedliner
  • July 24, 2011 at 2:38 am #31855
    Was wondering if anyone here has had any experience with the upol raptor bed liner kits? I have been using this stuff as an undercoating and had a problem with it lifting up in some areas. The areas that are lifting are areas that I sprayed over undercoating on the bottom of the cab of a truck that I am working on. I peeled the loose stuff up and the undercoating is sticky, not real sure what is up with that. Everything else that I am doing will be sprayed over areas that have been sandblasted and epoxied. ( I sprayed the epoxy today will shoot the bed liner tomorrow) I am just wondering if I should just start over with the stuff that was sprayed over the undercoating. Thanks for the help
    July 24, 2011 at 6:09 am #31859
    I think you answered your own question :cheer: I bet that the solvents from the raptor softened the undercoating and made it lift.We have done dozens of boxliners using the upol raptor kits plus my personal truck with no issues.
