urethane grade reducer
Home / Forums / Main Forum / Paint and Refinish / urethane grade reducer
- This topic has 5 replies, 6 voices, and was last updated 12 years, 3 months ago by don prcotor.
- September 24, 2012 at 4:24 pm #38364
I just painted a VW Bug …dissasembled and painted, then reassembled. I made sure to use enough base to get good coverage, like 5 coats. Funny thing though. Some parts came out slicker than others. I painted at seperate times. Perhaps I used a different brand reducer,but everything else the same. QUESTION…. Does it make any difference with the economy reducer compared to a premium? In you experinces? Thnks Bill
Attachments:September 24, 2012 at 4:28 pm #38365Yes, high grade solvents are expensive. Typically the cheaper it is the faster it is.
The old saying still holds true, you get what you pay for.
September 25, 2012 at 3:02 am #383675 coats of base is quite a bit of material and a ton of solvents.Why didn’t you use a tinted sealer or a dark gray to make life easier and allow faster coverage?Ryan is right you do get what you pay for with paint.
September 25, 2012 at 4:20 am #38368And why use a different brand of reducer? did you use different brand bases as well?
September 25, 2012 at 6:45 am #38371There u go, u answered u own question. Painted parts @ different times. Most likely, u used different psi when painting. Maybe some parts u didnt use enough reducer.
