Urethane or Ployester Surfacer
Home / Forums / Main Forum / Paint and Refinish / Urethane or Ployester Surfacer
- This topic has 4 replies, 5 voices, and was last updated 15 years ago by Anonymous.
Gotta question here, I’ve used Polyester surfacer in the past (1993) and had problems with checking and crazing (evercoat brand ). so since then i stopped using it and stayed with urethane primer surfacer. what do you guys use or prefer for primer surfacer? any economical brands? polyester or urethane?
November 28, 2009 at 3:36 am #17293i do poly on anything that i absoulutly dont want to shrink especially resto work the new polys have came along ways since 93 an yes im using the ever coat brand they got a new one thats called 4 ta 1 thats really nice funney that thats the mix ratio to keeps ya from over or under indexing it which can cause ya greif try it youll be suprized 😉
November 28, 2009 at 4:23 pm #17295i love polyester, i dont base directly on it though. i use it where you would use a glaze or need a light filling. i cut it with some 150 then urethane primer over it.
AnonymousNovember 28, 2009 at 10:59 pm #17311I usually only use it on resto work too. Big body repairs I’ll sometimes use it too, almost always top it with a urethane primer, lower end stuff I’ll use a urethane wet on wet sealer instead.
