water trap system?
Home / Forums / Main Forum / Paint and Refinish / water trap system?
- This topic has 8 replies, 5 voices, and was last updated 15 years, 8 months ago by J’s.
- December 20, 2009 at 6:13 am #18090
All I use are 2 Astro filter/regulator units that are knockoffs of the sharpe 606 units.
They were like $40/ea. back when I got ’em, think they’re a little more now.
Never had any problems, but my compressor doesn’t run much and has an automatic tank drain on it.
December 20, 2009 at 2:59 pm #18100We have a [url=http://www.sata.com/index.php?id=1069&L=11][b]SATA 444[/b] [/url]unit in the booth for final separation and filtration, but most of the hard work is done at the compressor, which has a refrigerated dryer built in.
December 21, 2009 at 11:11 pm #18172[b]airhead wrote:[/b]
[quote]now can i run this trap right out of the compressor to the hose and to the paint gun?[/quote]
You can, but you’re much better off having a decent length of metal pipe between the compressor and the trap. This will allow the air to cool before it gets to your trap, so more water will have condensed out of it, making the trap more effective.I have been running a small inline water trap (hooks into the air hose and into the pressure regulator) it looks like an orange ball.
seems to work pretty well… but i’m not exactly sure what they’re called. I’m sure there are many better solutions but i’m just a do it yourselfer and its cheap untill i can get a better dryer system.
[b]Andy T wrote:[/b]
[quote][b]airhead wrote:[/b]
You can, but you’re much better off having a decent length of metal pipe between the compressor and the trap. This will allow the air to cool before it gets to your trap, so more water will have condensed out of it, making the trap more effective.[/quote]I agree more metal line before trap like 20+ feet of it! you want that air to cool off first before it gets too any trap first! The more it cools the more water it gives up.
