Weld thru primer
Home / Forums / Main Forum / Auto Body Repair / Weld thru primer
- This topic has 7 replies, 7 voices, and was last updated 10 years, 9 months ago by john.
- February 6, 2014 at 5:44 am #45870
I never really liked it,and last time I checked chrysler did not want any used on their vehicles due to contamination and crappy welds with poor penetration.In theory if you have two pieces of sheet metal ready to weld with zinc coating on them from the factory you do not need weld thru primer.I had better luck using epoxy or etch primer on bare metal flanges and always put the spotwelds back in the same spot.I preferd doing it that way instead of cleaning the whole flange to bare metal and then adding weld thru primer,it held up better against corrosion.Just my thoughts….
February 7, 2014 at 5:41 am #45880This is what we have used at the shop for the last 8 years..http://www.amazon.com/U-Pol-Weld-Copper-Primer-Aerosol/dp/B003TQ9NFK
I would rather leave a flange bare than use transtar…..Just sayin :whistle: - AuthorPosts
