wet sand and polishing… DA vs block
Home / Forums / Main Forum / Paint and Refinish / wet sand and polishing… DA vs block
- This topic has 8 replies, 7 voices, and was last updated 14 years ago by TLB.
- August 14, 2011 at 10:31 pm #32439
DA, for the same reasons given above.
If I get any major chunks of dirt then I’ll block them out first to make sure they’re flat, but the majority of the time it’s just minor nibs,so the DA works fine.
August 18, 2011 at 10:27 am #32514Not with 600, no.
As a rule it would be 1500 dry on the DA, then 2000 or 3000 wet to reduce/ refine the sanding scratches to make buffing much quicker and easier.
I can get Abralon’s to last an age with a bit of moisture (Not wet). I find they clog real quick when wet. I Use a plant spray bottle with a mix of 4-1 with water and water based degreaser. A few light squirts on the abralon and away you go. I find the slight soapiness of the water based degreaser keeps the pad real clean.
I used one 2000 pad today for a Mondeo Bonnet, two wings and two doors. Still cutting great come the end..
