wetsan scartches
Home / Forums / Main Forum / Paint and Refinish / wetsan scartches
  • March 24, 2011 at 8:41 pm #29774
    i need help, i just finished painting my car and i got rid of the orangel peel with 2000 grit sandpaper, then i used ultimate compound from meguiaers to get rid of the scartches form the sanding,
    at first it did give me the mirror finish but if you look at it on the sun light yu can see the scratches am i missing something here could anyone give me some info please
    March 24, 2011 at 10:51 pm #29780
    you might want to hit it a second time around with compound and a wool pad.
    March 25, 2011 at 12:04 am #29782
    i didi like 3 times all ready
    March 25, 2011 at 12:22 am #29783
    If its a dark color you’ll have to go over it with a finer compound or scratches from the coarse compound will really show. I’m not familiar with that compound but you typically have a few different steps switching to a finer and finer compound.
    March 25, 2011 at 3:07 am #29785
    Is it the sand scratches that aren’t quite polished out or marks/swirl marks from the compound?
    As MoCoke said, if they are still sanding scratches you need to keep compounding somewhat agressively. If they are swirl marks, you need to move up to the next finer compound/polish.
    What type of polisher are you using (and at what speed). What kind of pad?
    March 25, 2011 at 4:27 am #29787
    what clear did u spray? thats kind of a draw back of wet sanding because its easy for the paper to carry dirt and cause deep scratches. as suggested u mite wanna try using 3000 grit on a da to refine the scratches up a bit and start over. maybe switch to a compound that works better on a HS clear if thats what u sprayed.
    April 14, 2011 at 1:40 am #30301
    i start with 1500 than go to 3000. compound than glaze.
