What guns are you guys using?
Home / Forums / Main Forum / Paint and Refinish / What guns are you guys using?
Viewing 15 posts - 1 through 15 (of 21 total)
  • July 26, 2010 at 11:59 am #23311
    Sup Everyone,
    Please post down what guns you use for each specific job (ex: primer, base coats, clears).
    I use:
    Base coats: Iwata LPH-400 w/ 1.3 orange cap.
    Clear coats: SATA Jet Digital 2000 RP w/ 1.4 cap
    Primers: Non-brand name HVLP gun w/ 1.8 cap.
    What about you guys?
    [b]Kudos,[/b]
    Jay
    July 26, 2010 at 12:22 pm #23312
    Base: Iwata WB400 WBX gold cap 1.3
    Clear: Iwata WB400 WB2 blue cap 1.3
    Primer: Devilbiss PRi 1.8
    July 26, 2010 at 3:05 pm #23318
    Primer Iwata LPH440 1.6
    Sealer Iwata W-400lv 1.4 or LPH-400 1.4
    Basecoat Sata 3000 hvlp 1.4HC and Tekna 1.4
    Clearcoat Sata 3000 RP 1.2 or 1.3(depends on weather) and sometimes Iwata W-400lv 1.3
    July 26, 2010 at 5:15 pm #23325
    Primer: SATAjet 100 BF HVLP 1.7
    Sealer: SATAJet 3000 HVLP 1.4
    Base: SATAjet 3000 HVLP Digital 1.3
    Clear: SATAjet 3000 RP Digital 1.3
    All guns used with 3M PPS cups.
    I thinks it’s obvious I am partial to SATA :rock
    July 26, 2010 at 8:40 pm #23328
    Primer-Eminent compliant gun with a 1.5(made in holland)these guns are tough as sh@t,we bought 4 of them in 1987 and replaced them last year.
    Sealer=Devilbiss plus with a 1.4
    WB basecoat=sata 3000 hvlp with a 1.4HC
    Single Stage=first gen Sata rp with a 1.4
    Clear=Sata rp 3000 with a 1.4
    Solvent base=Devilbiss plus with a 1.4 or first gen sata rp 1.4
    July 27, 2010 at 7:33 am #23358
    *Sealer gun: sata NR 2000 1.4 *.Autowave SATA 3000,1.4 . * HS+ Clear Sata 3000 1.3. All Sata’s for me 😉 Sikkens sealer,paint & Clear
    July 27, 2010 at 3:24 pm #23360
    polyprimer sata klc-p 2.5
    primer: sata 100b hvlp 1.9
    base: lph400 / orange 1.4
    clear: sata 3000rp 1.4 / iwata lph400 1.4
    touchup guns: lph80 1.0 / sata minijet 3000 1.0
    July 27, 2010 at 6:28 pm #23363
    Primer: War-Wick 878H 2.0
    Base metallics: Sata NR2000 1.4
    Base solids: Iwata LPH400 1.4 silver cap
    Clear: Iwata LPH400 and Sata NR2000
    Backup gun: Sata RP 1.4
    Mini gun: Iwata LPH80 1.2 and a few CAT mini guns
    Useless junk: Sharpe Finex
    July 27, 2010 at 9:38 pm #23365
    Primer/sealer – W400 LV2 with 1.3, 1.4 or 1.8 depending on application.
    Or Devilbiss PRI 1.6
    Basecoat – Iwata W400 WBX 1.3
    Clearcoat – Iwata WS400 1.3 Clear
    Mini gun – Iwata LPH80 1.2 E4
    July 28, 2010 at 12:25 am #23366
    Poly – Devilbiss FLG3 (1.8 – 2.2 Tip)
    Primer – Sharpe SGF98 1.5 Tip, Devilbiss FLG3 1.8 Tip
    Sealer – Devilbiss CVI HVLP 1.4 Tip, Sharpe T1-CG 1.4 tip
    Base – Sharpe SGF 98 1.4 Tip (I’ve tried many different base guns, and I just like the pattern on this POS.)
    Clear – Iwata LPH400, Devilbiss CVI Trans-Tech 1.4, Sata RP 1.3
    Worthless POS: Devilbiss Starterline. (Biggest waste of money ever.)
    July 28, 2010 at 12:50 am #23367
    Primer: HD eco roller with 5/8 nap
    Sealer: Whats that :blush:
    Base: Solids- HD eco roller 3/8 nap
    Metallic- Lowes Kobalt roller 1/8 nap
    Clear: Lowes Kobalt roller 3/4 nap for 1 coat application
    :stoned :stoned :stoned
    July 28, 2010 at 12:55 am #23368
    It shows Ding. :lol1 :lol1 :rofl :rofl
    July 30, 2010 at 7:44 am #23414
    Primer – Sata ??? (Shop Gun) Huge Tip
    Sealer – DeVilbiss GTI 1.3
    Base – Sata 3000 WSB 1.3
    Clear – Sata 3000 RP 1.3
    July 30, 2010 at 8:29 am #23415
    :hij:
    gophers – 22. cal (great for jammin)
    :squirrels, groundbirds, and even bear – 22. cal/ 20 gauge over under (nice overall gun)
    :deer – savage 110 (good for bigger jobs)
    :ducks – Remington 870 (nice wide pattern and works with water born)
    :whistle:
    All round favorite – crossbow :pcorn: (really quiet for night shooting) 😉
    I want a double barrel paint gun :stoned
    July 30, 2010 at 4:10 pm #23418
    [b]Stone wrote:[/b]
    [quote]:hij:
    :whistle:
    [b]I want a double barrel paint gun[/b] :stoned[/quote]
    …but could you handle a double barrel paint gun, it has a lot of kick when you pull the trigger. :lol1
