what inline filter to get for compressor?
Home / Forums / Main Forum / Paint and Refinish / what inline filter to get for compressor?
- This topic has 6 replies, 4 voices, and was last updated 12 years, 10 months ago by Agustin Ybarra.
hey guys going to be doin a respray soon what type of inline filter do you recommend? preferably from here http://www.spraygunsdirect.co.uk/products.php?page=1&pid=89&id=105
or if not from there another website that delivers to australia,
ok bit of update on my air system would like some more advice
i have a iron air compressor its 3hp, v-twin, 90lt tank, 309 lt per minute, and the pressure duty cycle is 6-8 bar, I’m running a 20mtr 10mm air hose off it,
is this ok to spray full cars? and also still after advice on filters
January 31, 2012 at 6:16 am #35654Need more info about your air system, is this a one time deal or is this something that is going to be used quite a bit more?
February 9, 2012 at 4:51 pm #35820something like this http://www.spraygunsdirect.co.uk/product.php?tid=105&products_id=2609
but you will also need a desiccant filter to remove moistureok bit of update on my air system would like some more advice
February 27, 2012 at 4:59 am #36010http://www.autorefinishdevilbiss.com/Division/Camair/AirControlandFiltration/QC3FilterDryerUnit.aspx
ths is what i use in the home shop i spray one car a month and have not had any problems i do not use a regulator at the gun i have a air cap tester and run 10psi at the cap and i have no problems with this filter or its quality of air supply. and i am on a 8hp 80 gal tank Camp/haus compressor and i am also in texas where spraying at 50% humidity is a common occurance
