what procedure would be best for refinishing
Home / Forums / Main Forum / Introductions / what procedure would be best for refinishing
  • February 25, 2010 at 12:02 am #19724
    Hi everyone, what is the best way to refinish a porsche hood? I has a couple of stone chips and I feather them out but did not go to metal. Should I prime the stone chips I feathered out or can I get away by putting sealer and paint. I am using dupont cromax pro. I suggested to my prepman that he should prime but somebody said it is not good to put too much product on it. As a painter, I say prime and block the area where paint have been feathered, then seal and paint. What do you think?
    February 25, 2010 at 12:21 am #19725
    ta be honest i would spot prime those spots then wetsand with 600 an paint
    February 25, 2010 at 12:30 am #19726
    X2
    February 25, 2010 at 12:56 am #19727
    well too late for primer, I spotted in the spot with sealer ( dupont 42440) and then seal the whole hood when the spot dries. I notice the feathered areas, should I block the area with 800 and the re-seal the whole thing? Can I put on too much sealer that there would be a problem with putting on cromax pro water base? I am new to the water.
