Which Clear coat???
Home / Forums / Main Forum / Paint and Refinish / Which Clear coat???
- This topic has 6 replies, 4 voices, and was last updated 14 years, 11 months ago by Pablo Claros.
- May 31, 2010 at 12:23 am #21679
Standox has a premium clear to this day it has the highest gloss ive ever since..I ve used dupont,spies,nason,standox,ppg and Rm clears i think dupont has a 4900 or 4300 clear that is okay and very easy to shoot…Premium took about 4 jobs until i got the hang of it
[b]Papipab wrote:[/b]
[quote]Standox has a premium clear to this day it has the highest gloss ive ever since..I ve used dupont,spies,nason,standox,ppg and Rm clears i think dupont has a 4900 or 4300 clear that is okay and very easy to shoot…Premium took about 4 jobs until i got the hang of it[/quote]So standox is good in your opinion but can you explain how you made it work for you
[b]grants_paint_shop wrote:[/b]
[quote]i use max mayer 0200 i think looks great :cheer:[/quote] :cheer:Mate try 0300 with the correct hardener and im sure you will be impressed. I use 0200 on all collision repair work but im looking for a clear that will produce a long term finish and high gloss finish.
June 3, 2010 at 5:00 am #21724Standox.
Dont use 15-60—too sensitivePremium Clear
2 to 1 with the 20 -30 hardner
5 percent 15-25 express thinner
Tight first coat – three inch from the panel moving about twice as fast as your used to at 6 inches
give it 10-15 minutes to flash ..18-20 if ur booth has bad airflow
then just give it a wet 2nd coat normal speed and normal distance
Becareful don’t let the clear build up to 3 coats on the blends in between panels
because it will run. Don’t stop at the end of panels either blend into each panelGood luck its a beautiful clear it might pinch but it buffs out perfectly
